i know it is possible but is it worth the effort?
hp..... this would go with a tune and down the road gears.
I read that the cobra and Mach 1 intake cams are an improvement but still nothing to write home about compared to how far the aftermarket has come.
good info.... i just saw a vid earlier a guy took a gt swapped in a teksid block and swapped in the 5.4 cams.
Best bang for the buck for a 4V cam is the Ford Racing cam set. You get an entire valvetrain for about $1200 bucks and it makes good power NA, has good manners and mileage, and also works pretty well with a blower.
Pete
If you wanted a decent cam upgrade with cheap cost, the best is to do what was mentioned above and use stock cams. The best combo you can put together is 96-98 Cobra exhaust cams and use like 01' cobra or mach 1 intake cams.
