i just bought a 94 4.6 tbird runs great so heres the problem at idle in park it sometimes has a hunting idle sometimes not idles around 800 sits in park idles fine. put in gear rpms drop and hunt real bad makes car shake alittle but it dont always hunt . you can stop at a stop sign and go no problem but if you sit at a light or in driveway in gear after a few seconds it dies . put car in park starts right back up next light does it again any ideas need the help
ok went to autozone and there were no codes also it does not do it when cold only after warmed up and it doesnt do it if i put it in nuetral while sitting at the lights cleaned maf havent got ti aic looks like a pita to get to and i couldnt find any where that sells a gasket for it ive also noticed it sounds like i have a sucking sound comeing from the black part on the aic
On the 94/95's, there's a "T" fitting on the back of the intake on the passenger side (IIRC) and it is notorious for breaking and causing a vacuum leak that will give you the symptom you describe.
ok, so i cleaned the maf and aic. had to take the aic off my dohc so i could make a gasket someone glued the one on my bird. when cleaning i noticed that the little divider on the bird one was open more than the one on my dohc. i put it back on still same problem , went and got another used one and its gaped like the dohc one i havent got to put it on yet. does this mean the original is bad. also does anyone know where to get the rubber t fitting on the back passenger side i believe its cracked up.
