Ok, I need to find the steel heater hose for a 95 3.8l that runs from the water pump over top of the intake manifold. The Ford dealer has one for $90 but can anyone point me to a website that might have one for cheaper?
did your rot out or did the rubber part rupture?
If you're looking for a new one, Ford would probably be the only source. If you are interested in a good used one, I probably have one in stock.
-Rod
It was rotted out right where it connects to the water pump. We may have found a way to fix it. The used one would be an option if it is in good shape. I'll have to work on it a little more tonight and see where it stands then.
