AED Specialist
Hey guys I have a broken end link on my Addco rear sway bar and I cannot find the paperwork to get the part number.
Anybody know the p.n. or the length, diameter and material of the bolt that holds them to the sway bar?
A-Train
Honestly I think those links are absolute junk. When I got my Addco bar the ones I got would not even assemble. I recomend using going to the GM dealer, I know I know, and buying a a pair of front end links for a 2006 Tahoe. That's what I am using and they work great. The GM links use 53 shore D durometer bushings and a 10mm bolt intended for withstanding loads around 10kN (about 2000lbs). They have a 135mm centerline, about 25-30mm shorter than stock.
-Miller
EDIT: Here's a picture of them installed on my car. I am not sure how much they run from the dealer since I got them for free from work since we are the supplier. :)
Also I dug up my paper work and the install sheet lists some part numbers but some are crossed out with another written in. The first number is the original number, if there is a second number it is written in.
Endlink Bolts: 1) RH235 2) RH222
Lock Nuts: 1) RJ307 2) RH304
Spacer Tubes: 1) RH062
Cup Washers: 1) RH107 2) RH109
Urethane Endlink Bushings: 1) UB614E
AED Specialist
Thanks...
Well I found the p.n. it's #016.
I do appreciate your additional info and I would have never thought to use anything GM on my Ford.
I'm in a pinch though and I just want to get a new pair.
A-Train
