1 - 16 of 16 Posts
Once you do the exhaust, who needs a radio? :)
My hero! Thanks Rick :)
are there any connector pinout diagrams for the EQ?
I don't have that available, sorry. You have the colors in that diagram, does that help?
I will have to check to see if I have this one. If I do, I will drop it in the mail for you. I have many of these manuals, but they weren't a complete set.
K I need some more stuff:
The EVTM may or not have this since it was a feature only used on the 20th anniversary cougars but, it might be there.
I need the schematic for the power driver seat WITH programmable memory control, as well as the page with the component location for the module.
Thanks
Connector C287: Under LH Side Of Instrument Panel, Near Fuse Panel
Connector C288: Under LH Side Of instrument Panel, At Fuse Panel
Splice S490: Under Drivers Seat Near Memory Module Take Out
Power Door Lock Actuator: In Door, Below Handle Switch
Power Door Lock Control Switch: Lower Center Of Door
Power Door Lock Relay: Under RH Front Seat
Power Door Unlock Relay: Under RH Front Seat
Power Lumbar Seat Compressor Motor: Under Seat
Power Lumbar Seat Switch: Side Of Seat
Power Mirror Switch: In Console
1997 Lincoln Mark VIII EVTM
Bump, I need a 97 or 98 Mark VIII headlight switch diagram :)
Here's a few pages for a 97 Mark VIII..
If this isn't what you need..I'm sure Rick has them for you..
I hope these help.. :thumbsup:
Discussion Starter #14
Thanks rayo, though I really need something with circuit descriptions or an internal diagram of the switch(like from the testing or power distribution section)
This one looks a little more in depth..
<img src="http://img145.imageshack.us/img145/9276/19971998lincolnmarkviii.jpg" width="800" height"1000" alt="the image" />
Discussion Starter #16
Bump
I'm in need of a pair of connector pinout diagrams for a 2003 Taurus/Sable. I need them for the the window and lock switches.
Thanks
1 - 16 of 16 Posts
