i'm looking for the bolt and offset bushing that will allow for adjustment of the rear toe angle. mine our froze. i will need them for both sides. I've tried every auto place in town including the ford dealership with no luck. thanks, Dave
your ford store cant order them?
so your talking about the rear adjuster bolt? the front just shows a bolt that also goes thru the compensator
Discussion Starter · #7 ·
yeah, it is supposed to have an offset bushing so you can slide the rear of the control arm in or out. if these are the same on each side i'd go buy two of what ford has, or i guess i could at least use the bolts for both if the bushings are differant.
