Hey guys/gals... I'm still new to the forum, so I appologize if this is in the wrong forum...but I need help bad!!
I gotta get this Bird running in 12 hours or I am screwed... its 1:30AM now...
Please help with any input.
Vehicle Info:
1994 Ford Thunderbird
4.6L V8
Problem:
The vehicle was running very well, then... there's fuel but no spark. When vehicle is turned on but not running. A box in the engine compartment, that is located exactly in front of the air box is making a humm and also changes pitch in the noise when it is disturbed/moved. (See pic for reference...)
What is this box?
Any ideas why it won't start now?
Does this box have anything to do with lack of spark?
<a href="http://photobucket.com" target="_blank"><img src="http://i71.photobucket.com/albums/i139/ATurner777/The%20Bird/Picture042.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Real desperate here, gotta get this bird running. Thank you all in advance.
Please reference this same topic with further discussion and troubleshooting. I am still new to the forum and thought I would try this section too, thanks!
http://forums.tccoa.com/showthread.php?t=89025
Andy
There is a duplicate post in the Club forum.
I agree with Sir William to check the crank position sensor.
To answer your first question it is called IRCM/CCRM it is a relay control module inside is the eec, fuel pump, wot, and fan control relays. If it is humming then I would check all powers & grounds to it. My guess would be you have a bad ground and the noise is the relays cycling off and on. This could be the cause of your lack of spark.
