I had a strong gas smell coming from my 4.6 engine...i wasn't sure if I was just running rich or if there was a leak. I finally found the problem, it was a split line. I called my local Ford dealership and went to my local parts store, they all said that the part was obsolete so they don't make it anymore...:(
It is the fuel rail crossover on the top front of the engine for a 1995 T-Bird 4.6
the engineering number on the tag is: F4SE-9F792AC
underneath that number it also has: 941010A
Thanks for any help guys!
I don’t believe the crossover hose was ever available as a stand alone part. Dealerships had the hose in bulk with the requisite thermal core shrinker.
Any hose shop should have aeroquip socketless hose that will be just fine as a replacement for ¼ the cost and requires no special tools.
Thanks guys, ya I ended up just using some hosing, just like the aeroquip, to make the crossover line with the heat sleeve around it.
