does anyone know the part# for the gasket that goes between the housing that the oil filter attaches to and the block? im leaking oil and its getting worse and it's a mess above the oil filter right where you see the bolts to attach the oil filter housing to the block
thanks alot guys, oh its a 93 3.8L
Dean
It is nice
I tried looking but couldn't find it. Try calling a local ford dealer is your best bet.
well i think i found it if anyone needs it, it ended up being the oil pump seal, had to buy a repair kit with couple gears just to get the seal, il be picking it up tomorrow when they open and do it so ill let you know how it turns out. i didnt know that the filter screws right onto the oil pump, i saw it in a repair book and thats what it said
any know how hard it will be to replace that gasket? all i see is drain the oil, take off the filter, and undo the 4(?) bolts holding it to the block then replace and reverse steps??
anything else i should know about?
