Does anyone know of a source to replace the fan blade on an 87 5l with AC? I’ve been unable to locate a new OEM replacement. Here is a pic (number on the fan is E65E-8600-AA).
The current blade has a crack:
Thanks.
1994 XR7 , 46 most every option. 66.000 miles. rustfree, from washington state.
86-93 mustang 5.0 is the same. any fox vendor has them . i even have 1. cracking is a common
problem with them.i had an 88 XR7
Discussion Starter · #3 ·
When I go to Rockauto, here is the part it shows for 86-93 Mustang:
It doesn’t have the same bolt pattern as mine and blade count is different. Can you cite a Dorman or other OEM supplier part number I can locate? Thank you.
mine is an F3ZZ # . was made for hd cooling , 4 bolt mount. 9 blade. check the
fox tbird cougar website.the mustang blade is about an inch smaller but has the 4 bolt mounting. people on the fox site have been using it. or check with your dealer for an nos piece.
this is taken from the fox tbird forum . the F3ZZ-8600-A is the updated mustang one.
i would take a pic of mine out of the box but camera is broke and i have a flip phone.--irv
