I need some help I have to find out what the spec's are on a f-150 for the front brake rotor's. I just need to know the minimum wear amount or even a link on where to find this? I looked on yahoo and found nothing. Any help would be greatly appreciated.
My fault 1997 I beleive it's 2 wheel drive It's my teacher's truck. His computer is down and I have to find this out for my last lab.
It should be stamped/cast on the rotor somewhere (usually in the hub area). :D
does that say the maximum amount of wear or the minimum for turning the rotor?
In my opinion, it is the same thing. :D
But since this question is for a test, then I don't know.
The only place where I know that it "should" list the actual minimum thickness (i.e. maximum wear) would be the specifications section of the OEM manual.
But that is just a guess. :thumbsup:
motor city poster
i believe dont laugh, but autozone.com has specs such as minimum rotor thickness and such..
i believe i have found that there before
Yeah you were right we had the truck in the air and it was stamped on the inside of the rotor!! Thank's for your help guys!!!!
