1 - 20 of 23 Posts
Fry Rice Specialist
need a pic of the front fender unbolt if anyone has one.
i need the pic of the side profile of the front frame without the fender bolt up to it. anyone have one or two that can post it? left or right doesn't matter.
thanks.
Whining Intakes Rock
car porn!
Fry Rice Specialist
thanks a lot for the pic. i appreciate it.
Fry Rice Specialist
also just wondering what are the black box near the door is for inside the fender?(not in the pic)
seems like for some vacumm stuff?
i think thats the cruise control vac canister. is it round?
If it's on the passenger side near the antenna, it's the vacuum canister. 89-93's had a spherical vacuum canister forward of the passenger front tire, the 94-97's had a kind of triangular one behind the passenger front tire.
-Rod
Fry Rice Specialist
what's those canister function for???
The vacuum canister acts as a vacuum reservoir/buffer for vacuum operated accessories, such as brakes, HVAC, etc.
-Rod
Plucked Bird
~~Hello
I you think that is bare you should see my 96 Thunderbird.
Right now she only has Rear Quarters, Rear bumper cover & trunk lid.
There is no interior except cut down steering wheel. No winshield, No nose, fenders, hood, doors, engine, Transmission. No front spring-shocks, no rear springs.
Soon to go:rear window, fuel tank, ABS Unit
First to Go in is the Roll Cage, With Custom subframe.
Shopping list:
351W 2bbl. carb + Duraspark II ing.
C4 w/wide ratio gears
3.90 open rear gear
Fuel cell
lexon Winshield
Racing seat
Griffin radiator(racing)
All Sport/SC controll arms(or urathane bushings)
Welded K's with steel mounts
1pc drive shaft
Need list:
GT40 Heads 64cc
Non ABS master cylinder for rear disc brakes
urthane bushings
Lexon winshield
2bbl. carb with 1.33 venturi's
Sponcer or Rich UNCLE!
PAUL
Fry Rice Specialist
Discussion Starter #14
if you have pic of it it will be great...
i like naked pic...:)
thats where the charcoal canister for the emssion system goes. its not a vac canister
That is incorrect.
In this picture, the charcoal canister is circled in yellow, the 89-93 vacuum canister is circled in red, and the blue arrow points to the location of the 94-97 vacuum canister.
-Rod
you are definitely correct.... good job
Thanks for the last pic Rod, I was wondering for a while what was the black box for.. :)
1 - 20 of 23 Posts
