Do you just need the line or fittings also?
How many feet do you need? I have some in my garage if I can lay my hands on it.
drag-aholic
any local trucking supply house in your area will have the line. Its the same as used on the air brake systems. I would use a DOT approved line.
The lows and ace in my area carries the line. Just bring a sample of your line in so you can make sure you get the correct size. If your using 3/8 line in the air ride world that's the o/d, in the plumbing world that would be the i/d. I almost screwed myself buying fittings the other day, luck for me I looked at the fittings closer right before I paid the casheir... lol
