1 - 12 of 12 Posts
Hey everyone, my wifes 2002 Taurus is acting up.
We are getting random misfires, and gas mileage has gone down.
I have replaced the fuel filter, plugs, wires, cleaned the MAF.
It finally threw some codes yesterday, being P0301, and P0316.
The first code is cylinder 1 misfire, and the second code was not in my book.
The plugs when they came out were a whiteish color, indicating to me, we are getting a lean condition.
I am going to try a few more things this evening, but, kind of at a loss as what to look for next.
Can someone give me an idea what to check?
In the past I have replaced the DPFE, EGR vaccum solenoid, cam position sensor, and I think thats it.(none of these were related to the problem I am having now).
High-Mileage 4.6L Thrasher
P0316=Misfire Detected On Startup (First 1000 Revolutions)
I'd say yiou've got an issue with either the coil pack system,or the injector. That thing uses that "6-pack" coil pack,right?
JL
I'll bet that it's the coil pack.
JL
I found a way to check the primary and secondary resistance online.....will checking those help to see if its bad?
Like, if the values I come up with are greater or lesser than what is posted, will that indicate a bad coil?
I also read that it could be a vacuum leak related issue.
I did recently change the overflow bottle on the car, but where its at, there is nothing that I could have pulled off, or damaged in the process.....but than again, maybe I did.
I fought a failing coil pack for about 2 years on my old '98 F150. It was next to impossible to diagnose,and only when I just broke down and changed BOTH coil packs on that truck did I fix the misfire issue. I tossed both coils-I never was able to isolate which one was at fault.
JL
Well, the coil was the main thing giving all the random misfires.
But, plugs and wires seemed to help as well.
Next up, tranny fluid and filter!
1 - 12 of 12 Posts
