Ok I have a part throttle miss and I have change the plugs, wires and coil packs and cleaned the MAF. The car runs strong but the miss is getting annoying but it don't do it all the time. Any other ideas on where to check thanks.
ChuckD
If you can, see which cylinder is missing and look at the plug for anything out of the ordinary. (covered with oil, burnt, buildup)
Maybe that'll give you another option to check out, not sure which options, but if you can describe the condition of the plug maybe someone will know a little more.
Well cleaned the MAF again and changed fuel filter and the plugs look fine with no signs of any build up. It only does it now under a load so I guess checking fuel pressure is the next step and maybe a new fuel pump.
ChuckD
