WOO HOOO FIXED !!!!!!!!!!!!!!!!!!!!!!!!
i bought a 95 w/4.6 and just put a 97 trans in it. before i did the trans the car will idle rough wont accelerate. un[pluged the maf it idled ok could accelerate. but under a load, trying to dirve it wont accelerate. is this the maf being bad? i hope you can under stand what im trying to say. thanks
i tried cleaning it nothing no change. so a new maf? will any 4.6 due? say out of a crown vic? are they all the same as long as they are from a 4.6?
clean your maf is a bs response here dude :)
you need to swap the 95 tcc solinoid into the 97 transmission, they are a different impedience.
Also you might need to use the 95 mlps, i'm not sure about that.
But I am sure that you have the wrong tcc in there.
JH
well i called my buddy at ford today i talked to a mech told him my problem he said change the maf so i'm going to switch the one in my 94 into the 95 and see if it works keeping my fingers crossed
well i got a tamper resistent torx bit took the maf out and cleaned it w/ a Q tip and then i changed the wires and cleaned the plugs....... and man it finally works!!!! thanks for all the help
