1 - 11 of 11 Posts
I have a 97 T-Bird LX. 4.6L V8 with 102,000 miles on it. Had new plugs and wires put on it 2 months ago, changed the fuel filter two weeks ago. Cleaned the MAF sensor today.
Now to the problem. I began noticing about 3 to 4 weeks back that my car was doing a bit of a shuddering/stumbling deal under light acceleration - city driving anywhere between 25-40mph. My first thought was bad gasoline, so I put some dry gas in her and topped her off. Didn't help the matter. Changed the fuel filter thinking maybe there was a clog, didn't help. Cleaned the MAF, didn't help.
I've been digging around to see what the issue is and I'm seeing a ton of possibilities. The car has a lean code on bank #7 I believe if I recall correctly. Some said it could be carbon build up and to clean the throttle body. Some said it could be the classic TC locking issue. I put some trans treatment in the car a few weeks ago which didn't help. Some said it could be a coil issue.
So at this point I'm trying to figure out which way to go first. Should I target the engine so more or should I target the transmission? I'm in school quite a way from home with limited tools and funds, so I quess I need some opinions from you guys. Where should I start to get this problem solved with as little pain as possible. Perhaps a tranny fluid/filter change or a good spray down with throttle body cleaner? I don't know when or if that has been done prior to my owning the vehicle in 2008.
How many miles does the transmission fluid have on it, and what color is it?
Tranny fluid is red. Doesn't look burnt or smell funny. Dunno how many miles are on the fluid.
Odd thing is that it runs great WOT from a stand still and has no issues running 65-80 on the interstate.
What kind of spark plugs were used? I'm new to the Ford thing but I think I read somewhere that these engines are touchy with aftermarket spark plugs.
Ran a scan.. got the codes P0172 and P0175. That narrows down the issues quite a bit. It's running rich or lean on both banks 1 and 2. Could be injectors, MAF, ignition, etc.
Change out the front o2 sensors (or use a scan tool to see if they are switching), and make sure you don't have vacuum or exhaust leaks. If they're stock, you need a set anyway. :)
Propane is way safer than the alternatives, although we are talking about spraying a combustible gas into the engine compartment, lol. Propane burns slower, and gives you more time to move.
And you get to see if your plug wires are leaking, lol.
There's hundreds of snake-oil fixes like the lubeguard that wont do anything for your trans. If its shuddering then Dr Trannys instant slip fix actually works -- I have it in my car.
Given the codes I would be inclined to side with Master486 on this one...
Changed coil packs. Rich codes no longer a problem. Had a misfire issue develop on cylinder 3, changed the spark plug, no more problems as of yet.
1 - 11 of 11 Posts
