1 - 12 of 12 Posts
i need some help guys, i have stock gears in my car and at 60mph i am at 2000rpm. what i have been told that is to high, i dont know if my O/D is working right. there is no light that turns on so at 9 im going to the parts store and getting a bulb for the light. im going to try that. is there an adjustment or somin that i need to do. any ideas im stumped.
Discussion Starter #2
i just got done replacing the bulb. the off O/D light doesnt come on when i drive it i cant get it to go out of O/D. us there any adjustment i can do.
Ya at 65 70 you should be at around or over 2000 rpms
o really someone told me at 60 i should be at 1400rpm, im havin a problem of not being able to get out of overdrive. i checked the swith just now and i have no connection when i push the buttom. whats your guys opinion.
I thought it doesn't hurt your car to stay in overdrive. because personally I just stay in o/d
but still i want to be able to take it out of O/D when i race.
i was wondering if anyone ever heard of that O/D swith going bad.
Take your shift knob off. There is a clip which needs to be pulled out - then pull up on the knob. You should see the OD connector, it will be a white plasitc bar with 2 wires. Touch the 2 contacts together with a screwdriver or something to see if the OD light will turn on.
-Andrey
thanks once again guys, i took my shifter boot off and there was tons of grease in there. i wiped the conection clean and it works. lol 5h of work for somthing that easy. but ya thanks once again.
motor city poster
in the front of the shifter itself, there should be a little slit in the leather, there is a plastic clip in there that needs to come out and then lift straight up on the leather knob
could i turn that o/d button into a switch and mount it somewhere else?? i was thinking right next to the trunk release button. good idea you think? i know it's not neccessary but ii could do it anywayz.
Yes you can, all you need is a momentary switch.
1 - 12 of 12 Posts
