I need to do some touchup on the car and well one fender could use a new coat entirely (lots of stone chips). Is it necessary to wetsand the paint before applying the clear coat?
Dim Bulb
If the chips are really bad and very noticeable, a coat of paint alone won't fill them. Ideally you should use some 400-800 grit to take down the area around the chips, or sand it all down and prime over the chips, then paint. It all depends on how much time and $ you have at your disposal
I would use some 320 and featheredge them to were you can't feel the chips no more. And use P320, you use wet.
Thanks guys. the fender Im gonna have to sand for sure. The others Im just gonna fill in the spots.
