Up for sale is a complete Ford 347. Everything listed is brand new, and in the original boxes as applicable. The long block has been assembled by CHP and has been sealed, sitting in the crate in my garage for the past 4 years. I just haven't found the time or money to finish the car.
The short block is a CHP Street Fighter Pro 347(all forged internals) built with 10.5:1 CR and 28oz balance, with some upgrades to the original package, such as upgraded ARP fasteners and stud girdle. The heads are unported AFR 185's. I want to sell everything together as a package deal. This is a complete motor, top to bottom, with ignition components. All you would need are a couple accessory brackets and pulleys. The long block is assembled, including the valve train. Here is the parts list of what is there:
CHP Street Fighter Pro 347 10.5:1CR
AFR 185cc 60cc Heads
Ed Curtis Custom Grind Cam (Spec Avail)
ARP 1/2" Head Studs
CHP Billet Double Roller Timing Set
CHP Front Cover
CHP Timing Cover bolts & Seal
CHP Hydraulic Roller Spider Retro Fit
CHP Street Fighter Main Girdle
Canton 7 Quart Oil Pan
Felpro Gasket Set
Crane 1.6 Roller Rockers
FRPP Roller Lifters
Manley One Piece Push Rods
Melling High Volume Oil Pump
Edelbrock High Flow WP
AGR Performance PS Pump
TF Track Heat Intake Manifold (Black)
Trick Flow Valve Covers (Black)
Power Bond Balancer
SFI 28oz Flex Plate
BBK 75mm Throttle Body
Pro-M 75mm Chrome MAF
FRPP 30# Injectors Flow Matched
Kirban AFPR
FRPP Chrome Water Neck
Stainless Engine Bolt Kit
Generic Chrome CIA
MSD Pro-Billet Distributor
MSD 6A Ignition Box
MSD Blaster Coil
MSD 8.5mm Wires
FRPP Red Wire Separators
PowerMaster 140 Amp Alternator
K&N 9" Cone Filter
K&N Gold Oil Filter (x2)
Looking for $9000 for everything listed, plus shipping, or pick up in Lincoln, Nebraska.
I also have most of what is needed to install this motor into an 89-93 SC, or NA 3.8 car. I'd include all of these items for an additional $500.
JetHot Coated MAC Shorty Headers
Poly Solid Motor Mounts
MotorCraft Upper Radiator Hose
MotorCraft Lower Radiator Hose
93 5.0 Wiring Harness & EEC (used)
93 5.0 Engine Mount Brackets (used)
Mustang 5.0 Fuel Rail(used)
Discussion Starter #2
I'll let all the motor and all related parts go for $8500! I've got a lot more than that invested, and it's all new!
Thomas
I can likely get this to the Shootout (central Indiana) next month if need be. If interested, let's talk and see if we can work something out! :(
Thomas
Open to reasonable offers...
Thomas
