1 - 12 of 12 Posts
Chapter Director Coordinator
That looks just like the one Ford put on my 96 when it bew up. It's the one you want.
that dont look like the one you need, it looks like the 99+ PI lower intake, the dr side (top side in pic) doesnt have the hole drilled for the second temp sensor that the tbirds have. In 99 they went to a single sensor that sent the signal to the eec then the eec sent the a signal to the gauge, on the old ones, one sensor for the gauge, and a second sensor to the eec.
id email the seller to find out what year car the intake came off of.
I have the same intake on my 97... use the lower part and bolt your upper intake stuff onto the new lower.
i know what he is talking about.. where did you put the other sensor?
JD
That IS a PI intake. It will bolt up to your heads but the ports on your heads are very much different from the ones on that intake and it is a VERY bad idea. But, it's your car. Do what you want with it.:rolleyes:
Good luck
Darrin
just received reply from the seller..
it is off of a 2003 GT..
i don't think it will work.. but cheap for anyone with PI heads..
Amateur Expert
His "Buy it now" price is $150. You can get a new knockoff '03 intake from KarKraft for $99 plus shipping, so unless you want a Ford part, it's not really a deal considering he won't let it go for less then $150.
yeah, I just got my new intake from www.karkraft.com yesterday. It was $109 plus s&h. It was a total of $123, but it was the intake and aluminum water x-over only.They are on sale right now, so if your interested, now is the time to buy.
Refrigerator Raider Hater
the KarKarft ones are also PI versions.
I picked up a slightly used NPI version for $75 about a month ago. they are out there, and cheap.
Does any one have a pic of that manifold with the new neck?. Is there an aftermarket all aluminum one?
No, It's just the coolant passage.
this is one from KarKraft, a PI piece, but the NPI looks the same.
the parts for the NPI engine are:
1 - 12 of 12 Posts
