I see that ignition coils run between $20 and $60. Is there really any difference? I'm tempted to go $40 range (just because that's about what my budget allows), and need to know if it's advisable to replace both at the same time, or is replacing just one OK?
I have reason to suspect that one is bad, as I get an intermittent misfire with this replacement I currently have. (Original pack had the electrical connector broken while we were replacing something else under the hood, so I got a cheap used coil pack, and the problem has persisted since then.)
Thanks a bunch for any guidance you can offer.
