Is it possible to make a new maf off of an 05 and newer mustang work with a 94 eec? The reason i am looking into this is because they are of a style where the sensor itself easily unbolts from the maf housing and can be switched to a larger housing. So since that is possible it would be possible to make a custom intake tube to utilize the ram air scoops on a cervini's hood and insert the sensor into this tube making for a very clean setup. thanks, Dave
Yes this can be done, yes it can be put into any size tube and tuned appropriately.
Discussion Starter · #5 ·
what i was gonna make was essentially a y pipe. i would have 1 tube coming off of each scoop with its own antenna at the scoop, then they would y together, once y'd the maf and temp sensores would be mounted there.
you can do that with other mafs too as long as it is tuned. the stock maf can be unbolted as long as you make a custom mounting plate for it and sampling tube
