Maybe I'm the first but who cares. For along time I have heard that nobody makes a polyurethane replacement for the Lower Rear control arms! whether this is info is true or not I'm here to tell you that there is!
The PROTHANE 99-04 Mustang Cobra IRS C-ARM Bushing Kit #6-311-BL uses the same size bushings as the Thunderbird/Cougar/MarkVIII
I just pressed out mine and they are exactly the same!
Just thought I'd share that info with the rest of yah.
Also just a FYI I didnt know the Mark VIII used a Tubular rear sway bar as compared to the Solid bar the Tbird has,, savings of almost 5-10lbs!
Brad M
Brad M
