Just finished a few new kits for the stock rear sway bar. The kits include sway bar bushings, end link grommets/washers, and replacement end link bushings. This kits is for stock sway bars only. The sway bar sizes are 23mm, 24mm, 25mm, 27mm depending on year this covers all the 89-97 Thunderbird rear sway bars. SC and sport equiped cars have a larger 3/4" endlink bushing all others used a smaller 5/8". We will have the parts page updated in a few days with more pictures. Price for each kit is $35.00
Rich
The poly bushings reduce the compression found in rubber. Rubber bushings compress based on the durometer or hardness. The rubber has a durometer of 80 vs the poly durometer of 95. The poly will never dryrot and with the endlink bushings it will provide a better than stock performance. The kit also allows you to save money by giving you a way to rebuild the endlinks which can cost $30 alone. Ride quality is not reduced but handling is much improved. After installing the kit you will notice a difference in reduced understeer as well as all around handling.
Rich
I was wondering when someone was gonna offer urethane endlink bushings, that's all that fails on them and they are expensive buggers.
