:zwthstpd: the gains from a pi intake swap would make everything you'll have to do to get the newer style intake on worth it
also, if the intake you found doesnt have the aluminum crossover dont even bother with it
the parts needed for the newer intakes to work on the 94/5s:
-intake manifold(duh:tongue: )
-96/7 plenum/throttle body/iac
-96/7 throttle cable
-96/7 fuel lines and rails, or just the 96-98? crown vic rails and reuse your stock lines
-96/7 egr tube
-96/7 egr valve
-newer alternator bracket
-96/7 vacuum harness, plus various other hoses
-96/7 intake tube
the wiring harness has to be modified too, the tps, iac, vacuum regulator connectors all have to be lengthened a bit
for the PI intake the only other things needed are the heater tube, water pump nipple, PI gaskets and rtv, and drill/tap the 2nd hole for the temp sensor on the crossover
