1 - 20 of 70 Posts
I just wanted to put a couple pics up of my 97 Thunderbird to look at if anyone wanted. Its mostly stock right now but i got plans for it, also its my first car and im just getting into the mechanics side so still have much to learn. Anyway here it is.
Car looks good! Get it a good wax and clearcoat and the paint will last longer.
Thanks, and yeah i want to get a couple of the chips filled in and get rid of the scratches. Been waiting to do that before i wax it. Probably smarter just to wax it when i can instead of waiting.
Wow, good lookin Bird. Is it the 4.6? What mods do you have planned.
Welcome to TCCoA
Yes it is the 4.6 and just appearance wise i was considering getting the wings west kit for it i think it looks the best on the 97 without going overboard, also i want to add the factory style wing and MAYBE an aftermarket hood. The wheels on it are nice but i want a bit more aggressive stance so hopefully some 17x8s(possibly 17x9 in rear) will get rid of some of that wheel gap then lower it if it doesn't. Etc.
373 gears in the differential maybe trac-lock, better driveshaft, gonna have a guy in town build the transmission for me, think he'll install the tc to, want to do pi intake swap, better intake system(are there cold air intakes made for the bird specifically?), get a chip from scp, and more i dont remember right now haha.
Oh right and of course the exhaust. Got a guy in town gonna build something custom for it. Full exhaust, headers too
You already have a cold air intake; if you want to upgrade it, search out the 2002 GT maf upgrade, before you get a tune.
You need a tune for that upgrade.
Instead of rebuilding your transmission, find a 2002 gran marquis or Crown vit transmission, and have that rebuilt; it already has almost all the upgrade parts you'd want.
I'd search here for the mods you're considering; there's a LOT of info here about all of it.
For one, a PI intake mod will lose midrange rpm power, but extend the rev limit. Few people spend a lot of time over 4500 RPM's, so that may not be a great mod for you.
I have a Cougar modded, and a Tbird that's not, and in most situations, the tbird is more fun.
It runs out of steam on the interstate, but the difference between 120 and 145 isn't all that important on street cars.
Thanks for the transmission info. The car already has a cold air intake??
Almost all cars come with a cold air intake - the intake source is outside air. Switching to an open element cone style filter changes it to a hot air intake. But it looks nice!
A stock engine doesn't need any more air than a panel filter can provide.
Al
Al
Wow thats cool, you said almost all cars though, how could i check, thanks.
I have a Lincoln Mark-VIII '93 single piece driveshaft available if you're interested. These are a direct bolt on drive shafts for the Cougar / Thunderbird. Short of going full custom driveshaft, these are the best and some of the hardest driveshafts to come by. Send me a PM if you're interested. We are both in California, but several hours apart. I'm in 92220 / 92223 area for reference.
Headers here in California are going to be difficult due to emissions regulations. You might be better off getting your stock ones (or get a set of spares from a junk yard Thunderbird / Cougar) and have them ported. They'll be stock but with better flow due to being ported, no emissions place will be the wiser.
Definitely interested about the driveshaft. I figured id run into the emissions problem here soon enough, what all can we get away with, do you know. Thats partially why im undecided on what i want to do with intake. Also are the headers cast?
If you look at your T-Bird, there should be a plastic tube attached to the underside of the airbox that goes down behind the fender. It pulls in outside air, which is the definition of "cold air". You would have to take out the filter to see the start of the tube, or fender liner to see the whole thing.
Pretty much all cars sold today are that way. In fact, I bet you can't find a newish car that doesn't pull air into the engine from outside the engine compartment.
Al
Discussion Starter #15
Good to know. So a better air filter along with an 02 gt maf sensor would be a pretty good setup for street use, how about the throttle body what what be better options for that? Or is the factory one fine. Paired with a tune of course get everything running right. Is that really all cold air intakes are though, a connection to the outside air? Thought there was more to them than that
Well, I can tell you I got away with my PI intake and cams. I also have a set of High Flow CATs and mine passed the sniffer test with flying colors last time she was due for testing. If you don't know a guy for testing, it'll definitely be more difficult. Headers on our car are a big no-no here in our state of California, which is why I said you're better off getting a set of OEM headers ported. There's even a few threads here on how ported headers perform better than shorty headers and some mid-length headers. Porting OEM headers is probably also cheaper than new headers, but don't quote me on that.
The mod for the 02 GT maf means changing the airbox to a GT airbox; it has a cone filter, and has to be modded so it pulls air thru the same hole as factory.
A cheap and easy mod to the stock airbox is to remove it, and remove the inlet restrictor that's under the airbox, in the fenderwell.
https://www.tccoa.com/forums/6-general-tech/92763-just-heads-up-air-silencer.html
It sucks air thru a hole the size of a quarter, lol.
Don't go to a K&N filter, they get the maf dirty, and result in constant cleaning of the MAF.
Just replace the stock one every oil change, the fram ones are cheap at RA.
Don't use a fram oil filter, tho. Just the air filter. Use a Motorcraft oil filter.
Discussion Starter #18
So this silencer just pops out? Because its a 97 i shouldn't have to remove the fender right, also it will still pull air from the outside? Ill probably look at it tomorrow but asking for reference.
Discussion Starter #19
Also Grog6 earlier you said something about going 145, how attainable is it to hit those speeds with these cars? Im sure you had to put some good money in it for that. I dont plan on driving those speeds, but it is kinda a personal goal of mine to outrun my buddy in his new Camaro 😄, which i know tops out at 141. What kind of numbers have you guys hit without the speed limiter, and getting a better driveshaft on there?
The silencer doesn't pop out. You have to get to it through the fender still. You have to remove the intake tube from the MAF forward in the engine compartment. Once removed, you'll see three bolts attaching the resonator box to the body of the car. Remove those bolts. Once they've been removed, the resonator is loose and can be pulled through the fender.
In all my years here on TCCOA, I don't think I've ever seen anyone hit 145, but plenty of people have claimed going over 120. And yes, lots of money is required to make this happen. Certainly less money than buying a new car though....
1 - 20 of 70 Posts
