1 - 2 of 2 Posts
i have a 1990 nissan stanza as a winter beater...i was doing some driving in town today, and i went to shift into 3rd gear...and nothing happened the engine just revved up like it was in nutral....i had to pull it off the road cause i could not get it back in gear....when i finally did i drove it home, shifting from 2nd to 4th, skipping 3rd completly....im not good on manuals...so mabey you guys can help me out...my cougar is in my garage with the tranny out, and this is my only form of transportation
thanks,
nate
Take it out in a field and shoot it. :D Or, you can check the shifter cables, the fluid level in the slave cylinder's master cylinder (if it's hydraulic) or, if all of that is ok, you probably lost third gear and the others won't be far behind. Check out http://www.nissanforums.com for more info.
1 - 2 of 2 Posts
