1 - 15 of 15 Posts
Nitrous Switches and Gauges
I was just wondering if anyone has pictures of their nitrous switches/switch panels? I am trying to decide which route to go and wheres the best place to get them at?
I have seen panels ranging from 50 - 150 dollars and wondering what others have used effieciantly?
Thanks
Dave
1 more question: I currently have an Autometer Phantom Nitrous Pressure Gauge, It is mechanical and has a rather large(thick) braided line. I would like to run this through the A pillar on the triple gauge pod, and wanna know if you can buy a smaller braided line or do I have to mount on the bottle?
Dave
This is where i put mine. They are from left to right, nitrous, purge, and heater. I will prob. move them sometime down into the ashtray and cover them up. But for now they are staying because i'm too lazy to move all the wiring. :cool:
As for the pressure gauge, i have one as well but i didn't want to mount it in the car. Only because that braided line is hard to work with. Its 4an line, but i think you can get adapters and change it over to 3an line....which is the same as your nitrous line that goes to the nozzle. You would need to tap in-line with the supply line using a t-fitting. IMO i think its not worth having in the car, only because, how often do you need to see nitrous pressure, or how often with the bottle be in the car, with the valve open, other than the track.
The guage that i have is an external mount, with no lights or anything. It's mounted on the bottle and i just use it in between runs to see what the pressure is at. If you dont have a heater, you'll only see about 650-700 psi. I got my heater this year ( NOS new for 35 bucks :D ..ebay...) and it keeps the pressure at a solid 950psi. Here's a pic again... Oh and if you're looking for a place for the purge....you can kinda see where i put mine...its in the cowl...a small clear tube.
I was only going to put it in the car because, it's one of the 80 dollar autometer phantom gauges, and it would leave one less space in the triple gauge pod, so now I need to buy two more gauges instead of 1, oh well. I bought the t-fitting already, it'll be here monday, so until then.
http://www.speedshop.org/store/scripts/prodView.asp?idproduct=88
This is the switch panel I will go with for the 3rd hole in the pod I guess, even though 150 bucks is alot. It looks awsome though.
Dave
Whining Intakes Rock
Do you need to have a blow down tube if you go to the track?
Only if the bottle is in the passenger compartment of the car. Like a hatchback or something. You're suposed to have a firewall in the trunk for it to be track legal, but the rear seats seal off the bottle and its perfectly fine not to have one.
$150 for a panel, or $150 for nitrous, or somethign else more important.
That's how I look at it anyways.
I just mounted my switches in the center console storage thing. Hidden, easily used, etc...
It's just a few switches and a button, nothing that is gonna stand out, unless that is what you are gong for then a panel like that would be ideal.
Dave
Just got the same Gauge, was wondering that myself
Formerly Fdawg97LX
dave,
that switch panel is a bit pricey but i think it will look sweet in the gauge pod. when i was thinking about n2o i was planning on mounting the switches in the bottom din slot on the dash and eliminating my ash tray. i think you might have the message center down there though, right? i'm keeping the bird now, a bullitt is just out of my price range right now while i'm in school, so i got a few mods in mind for the bird again. no gonna go as crazy as i had planned before but just a couple of things. let me know when u and mark put the n2o in, if its a sunday i'll give u guys a hand cuz i work mon-sat.
frank
I think a really cool place to hide the nitrous switch is if you could wire it where the OD button is on the shifter. :D
Been there done that.
I was the first person I'm aware of to wire up their factory O/D button as a nitrous trigger. The wiring is still all there, but I don't have the nitrous anymore. I sold it to Joel so he could blow up intakes. I just used a DPDT switch to swap the operation of the momentary SPST shifter button between O/D Cancel and Nitrous Trigger. :)
1 - 15 of 15 Posts
