I just put on a new pair! Geeeeeez I love these things!
They make such a difference!
What kind of Nitto's???
555, drag radials?????
Any idea on wear rate??
Traction ?
Temp ?
Info should be on the side of the tire. I'm needing tires again soon.
yeah the 555R's. They'll typically last me around 10-12K miles racing occasionally.
I usually run them at 35 unless im racing then they're at 19psi.
As far as traction and temp goes. What exactly did you need to know?
http://www.nittotire.com/mainframe.asp
Under 555, they have a both a street tire and a drag radial.
555
treadwear:300
traction: A
temp: A
555R (drag radial)
treadwear:100
traction: A
temp: A
The 555R is primarily for drag use, would provide better traction, but and would be fairly dangerous in rain and snow. Not that you or I worry about snow, but they will wear fast on the street. I got 35k out of BFG radial T/As with about 95% street 5% strip use. i will probably use the 555.
Geek w/Gearhead Complex
how much those run a piece?
ward
If you want traction you better air those puppies down to about 13 PSI! Go get those slips.
Re: ward
I've found that they best work for me at around 18 psi.
