ok guys and gals i havent been on in a while but my car is finally back together but i got one small hoefully prob #1 and #6 cylander have no compression so if someone could give me some tips as what it could be lol thanks much
justin
thats not good... absolutely no compression could be caused by a valve stuck open, a broken connecting rod, or a broken piston.
First question: Have you done any major engine work lately?
Second question: Have you beat the living crap out of your engine lately?
yea you gotta tell us everything that you have done to it/has been done to it in the past, so we can have a better clue.....when you say your car is "finally back together", what exactly does that mean? you been tinkering with it?
i have totally rebuilt the motor bare block up
yup
Off the top of my head, no compression could be:
Ring gaps improperly aligned. (I've known people to install the rings with the gaps lined up (or not even worry about where the gaps were)
Improperly torqued down head or warped heads
As mentioned a valvetrain or valve sealing issue.
Please understand that I don't know your level of expertise, nor what “I have totally rebuilt the motor bare block up” actually encompasses, so please don't be offended if some of these sound simple. :thumbsup:
I would do a leak down test and see exactly where you’re losing the pressure. If the air comes out the crankcase, you have a ring/piston/bore problem; if it comes out the exhaust, you have an exhaust valve/seat/head problem; if it comes out the intake, you have an intake valve/seat/head problem.
Just my .02 and good luck!!
I would also make sure that the cam timing is set correctly. If the timing was off the valves would open and close at the wrong time.
