Well the lights and everything stays on while you try to turn it over. fuel pump engages and both cam/crank sensors are connected and everything worked before hand. battery reads 12.45 volts and search didnt help....starter reads 12.6 volts from + terminal to engine block. i even put on my old starter that still works.
you can move the shifter into any gear without pressing on the brake as long as the key is in the ignition.
too tired to go on. car is 99% ready, just need it to start lol
UPDATE: the mlps was damaged during the swap. got a new one 30 minutes ago and everything is fine.
