Have spark *ouch*.
Believe have fuel, fuel pressure (the best I could test) 18PSI on one crank but on 3-4 cranks gets to 40 PSI (35-45 is normal), now I could not connect to the DLC to just engage the fuel pump.
Starter turns but blasted engine will not fire. Have new fuel filter too.
Discussion Starter #2 (Edited)
Prob found, injectors not fireing. Testing them w/ a noid set in the morning. Its ok to crank/start engine without the intake(upper) on anit it? (has to come off to get to injectors).
Didn't get it to fire though until starter fluid was added, any idea why injectors not fireings? DIS and EEC-V
We fired, replaced rail, injectors and regualtor form my old engine.
Noid light showed they were getting signal so I assumed was a mechanical failure.
