I have a parts car that doesn't have keys or a steering wheel for that matter. I need to bust the steering column loose so I can steer the thing into my driveway. What do I need to be looking for?
those guys will be REALLY upset when they realize that someone built the car backwards and put the steering wheel on the wrong side.Before you think about doing that,Watch this video.These guys had the keys in the ignition too.
http://videos.streetfire.net/video/f89e08cc-6c0e-4ae3-a1bd-989900ffbe9c.htm
Thanks for the tip, Rod. I'm not sure why I didn't think of this. Sometimes I think my brain doesn't work!If you just need to steer it (don't need to get it out of park), just disconnect the steering column from the steering shaft at the u-joint under the dash. You'll just need to remove one 13mm bolt. Then you can steer the car by physically turning the tires (from outside the car).
-Rod
