Ford Performance/SVO M112.What kind of blower is that?
Im looking for a Roush casting now. Cause I want to put one on a Roush Thunderbird.
Its not a Mustang harness. It was on another Bird before I got it.Nope. 🤣
Yeah, the original "kit" did not include an engine wire harness. Although the vacuum harness did have labels.Its not a Mustang harness. It was on another Bird before I got it.
Admittedly theres some fixes it needs. Like replacing the solid core wires for braided. But thats neither here no there
Yeah the IAC and Temp sensor plugs are extended with solid core.Yeah, the original "kit" did not include an engine wire harness. Although the vacuum harness did have labels.
Solid wires ?? 🤔 sounds legit.
Yes. Ill post photos in a bit but the harness wont work. Ill need to modify mine.Was Jamie's car a 94-95?
Its like that with the NA intakes too, it’s a dry hole. The head castings and intake gaskets are left/right interchangable, remember, that hole is the thermostat bypass on the left head, while on the right head it simply goes unused to nowhereView attachment 49180
@Trunk Monkey @Paulyrats and anyone else with an SVO.
Was working on finishing up my vacuum tree and noticed part of the intake gasket on the passenger side rear is exposed. I dont remember noticing it on my PI intake. Can one of yall look at your cars and see if its exposed for you too? If not I think I need to pull the blower off.
Its lined up everywhere else, all bolts threaded in and the snout pulley is in line with every other pulley on the engine.
Thanks Matt.Its like that with the NA intakes too, it’s a dry hole. The head castings and intake gaskets are left/right interchangable, remember, that hole is the thermostat bypass on the left head, while on the right head it simply goes unused to nowhere
Hopefully. My 4R70w leaked like a sieve(part of the motivating factor with the manual swap) which turned out to be the pump seal, it trailed down through the TC plug and at speed soaked around the pan so it was hard to pinpoint it’s origin. I think the dipstick tube seal leaked as well even though I replaced that with that transView attachment 49303
Switched out the trans pan gasket, filter, and dip stick O ring. Hoping that solves my transmission leak.
This is the #1 reason why I parked mine. #2 was obviously suspension. I have the parts to do everything already, but yeah....My 4R70w leaked like a sieve(part of the motivating factor with the manual swap) which turned out to be the pump seal,
