1 - 20 of 24 Posts
I have a 1997 cougar 4.6 I am thinking of cutting the mufflers off and keeping the rest of the exaust the same because of emishion tests how would it sound is there any sound clips of this
Thank you
Well, here is a clip of my 95 4.6 w/ the resonator taken out and straight pipe in it's place and the mufflers cut off and straight pipe there as well. Sounds better than stock, but to raspy in the high revs. This was taken w/ a digital camera so the quality isn't the best, but it may give you an idea. I drop it into gear towards the end as you can tell by the idle drop.
I will be getting full exhast done eventually.
Jay
http://smg.photobucket.com/albums/v92/FordMan77/?action=view&current=t-birdrev.flv
Thank you
Dont advise it, itll sound like poop. Straight pipes=redneck and ghetto at the same time.:D
i dunno for it being cheap and easy i AM a fan of Fordman77's exhaust. nice and simple and better than stock.IMO
why dont you put a dynomax bullet in place of the resonator. they only cost $30 at summit.
strait pipes sound like poo!
or a glasspack, they are even cheaper lol
buy good mufflers of your choice, do not make the same mistake that i did...cutting them off.sounds like crap and you lose some bottom end.i grabbed some dynomax turbo's not the best i know,but they have a nice sound and they aren't too expensive you will regret the chop job. i did.
Eh dont do it... its cheap yes, but invest in some sort of muffler. Magnaflow is a great sound. True duels will make it sound even better. Worth the time and money.
No mufflers sound like sh*t after 2k RPM... all I gotta say is Got Rice?
I've been wanting to hear something like that for a long time. So, something is better than nothing? I'm glad I haven't cut my mufflers off, yet. Would just some glasspacks instead sound 'OK'?
Discussion Starter #16
thanks for all the help I priced a dyno max cat back system today $500.00 is this system any good
thank you
It would be cheaper to buy 2 mufflers and have them welded on and get rid of all the garbage underneath like the 3rd acat and resonator. The best single thing I did to my car was the exhaust.
Where can you buy off road pipes / test pipes? I have 2 dodge stealths. The twin turbo one has custom true duals with no mufflers/no cats. But for OTHER one, online at a place called... maximalperformance.com, I believe, I bought a 'test pipe' for it. It came with, the pipe (duh), new bolts/washers and gaskets for $40. It was meant to replace the catalytic converter. It was a perfect fit, and gave the car a nice deeper sound. I already had a flowmaster muffler on this one. It was NA, btw. So, is there anywhere that someone makes something like that? Or am I going to have to fabricate something myself? Something to replace both the 3rd cat AND resonator. Then, I'll put some decent mufflers on and that should sound alright. I'm not worried about a high dollar exhaust because I don't have anything 'high dollar' done to the motor. It's bone stock.
i tried glasspacks but they were only cheap ones and they don't last very long it's up to you to decide. when i get on the throttle,which is everyday it's loud enuf...
1 - 20 of 24 Posts
