Im looking at a 94 and it will not go into reverse. I have rebuilt a few AOD`s so I do know something about transmissions but im wondering if this is a major problem with the trans or maybe a easy fix? Could it be just a MLPS or wiring problem? Im thinking bad reverse band or clutch. Thanks, Mark
THX I think im looking at a rebuild or used trans. Would you know if I could use a 98 E250 trans from a 4.2 with my valve body and shift solenoids?
No wrong bolt pattern. I would venture to say something is broken, do all the other gears work correctly? If the fwd is welded the overdrive will not work.
Alan
