1 - 10 of 10 Posts
affter everything else this car has been through...
it is getting gas, so the crank sensor is working
guy at autozone said it might be the ignition controller.
is there anything else that might be causing this? (I'm waiting for a new one to get here, just wondering if I should be looking elsewhere, and where to look if it isn't that)
Getting gas does not mean the crank sensor is working. It means the fuel pump is working.
The crank sensor and the connector/wiring at the connector is the first thing to check.
absolutely right. had that problem before where i was getting fuel but not ignition, it was indeed a crank sensor that was bad. granted it was on an old 5.0 engine.
Just unbolt it and let it hang there, that will give you enough room to get the sensor out. No need to discharge the system or disconnect the lines.
There's three 10mm bolts. I replaced the sensor on the 97 this past winter, took me about 30 minutes.
okay, that was fun, but...still not there
at least I know I won't need to do that again for a while
time to recheck the wires
scratch that, my tester is fried...:-(
good news tho, the tach is working
is there a fuse I should be looking for?
work got in the way,
I've replaced every electrical part that could be involved, It looks like I get to pull the covers off and see...
1 - 10 of 10 Posts
