Well, I replaced my heater core this last weekend since it's had a slight leak for a while, and I need heat as we get into winter. Since then, I've been unable to get the car to start. I had the heater core buttoned up, and was starting to put the interior back together, when I decided to try and start it so I can fill up the cooling system. I got the steering column back in, and the four (five, if you count the ignition switch bolted to the column) connectors underneath it hooked up, but when I go to start it, nothing. No sound like the fuel pump being primed, and the starter does not engage. There's a faint click from under the hood when the key first goes from OFF into the RUN position. When I turn the key from RUN to START, the voltage meter drops significantly, but nothing happens.
My first guess was that I simply forgot to hook something up when putting everything back together, so I double-checked every connector, and it's all snug. I used Sir William's method to get the dash out of the way enough to replace the core, so a lot of the ECU connectors never got unplugged to begin with. However, if I leave the car in RUN for a few seconds, the airbag light will blink a code 12 at me, which is low voltage to the airbag module. Voltage at the battery is 12.7. I did find one extra connector that isn't mentioned anywhere in timb's article, and I must've missed on my first tear-down. Here's a picture of it:
Asides from that, I've checked all the fuses, and the inertia switch. Still nothin'. Help?
Edit: Pulled a code P0232 (fuel pump secondary circuit high), but I believe that pops up whenever you trip the inertia switch. Just mentioning it in case it's related.
