1 - 10 of 10 Posts
About 75% of the time when i start my car in the morning and sometimes after work, the engine makes this sound. I dont want to say its a rod knock or something like that. It goes away as soon as it starts to build oil pressure. It doesnt do it every time. It has to sit for atleast 8 hours for it to do it. It has good oil pressure and it doesnt make any other noise. any ideas. I am think maybe something to do with the oil pump? I am not to familiar with the 4.6
I have a slight noise on startup as well with my PI motor. Like yours, it only happens with cold, and only lasts a minute or two. After listening to mine closely, it seems to sound like piston "chatter". It does not sound like knocking/pinging/detonation. However, my motor also ticks at all times, seems to come from rear of passenger side head. Think that noise is a hydraulic lifter clogged/dirty, but seafoam hasnt done anything to help it.
Anybody had any experiences with these noises? My engine runs well, idles fairly smooth and pulls hard, but the noises concearn me. I just hope this motor lasts until I have time to pull motor, have it Big bored and supercharged ;)
Mine would do that at startup when I didn't use a Motorcraft oil filter. I was told that they have a anti-drainback valve. I have been using nothing but Motorcraft filters ever since, and have had no noise for the past 65k. Hope this helps.
Jim
that and try switching to a 5w oil... the lower viscosity on startup means oil gets in there faster...
Next time you do an oil change, cut open your oil filter. My engine was making a nice little rattle for the first few seconds on startup right before it spun the #8 rod bearing.
-Rod
most common problem on a 4.6 is the a filter that dont have the anti drain back valve, if not sure use a motorcraft, also if the lifters have alot of miles on them they will clatter first few seconds cause they lose there prim over night if they have a some miles on them
Robert
Rod!!! Dont Scare The Poor Fella!!!
other than start up it doesnt make any noise. and it doesnt do it every time. Also it doesnt sound like a rod knock. i am hoping it is not a rod knock
1 - 10 of 10 Posts
