Recently i put a post up about hissing noises coming from around the t.b. well, after several days of looking and listening, i think its the injectors. the noise goes away when throttle is applied, but returns at idle. sometimes the car still gets the "shakes" likes its gonna die...but applyling gas cures it until i return to idle.
02 Explorer Pioneer
Vacuum leaks can be hard to hear when you bring an engine off idle. I would continue to look for that.
Finally had time to look and i think i found the problem.
I took the intake tube off and found a black plastic hard line goin from behind the t.b. to the lower part of the front passenger side head. i looked at both ends, and both were soft plastic that had cracks in them....so once it stops raining, ill see if new hose solves everything
