so I am throwing some codes on the old taurus...does anyone see anything that would give me a starting point..perhaps a common relation between these codes? 172, 326, 327, 634. I swapped the mlps with a known good one, and code 634 did not go away.
Thank you in advance.
I don't think it is not that anybody doesn't want to help, just that most of us are not familiar with the Taurus. Those codes are not OBD2 codes that 94-97 Tbird uses. Maybe if you post what the text of the codes are somebody may have a clue.
Pedal Faster
Well it just so happens that I have my Ford Fuel Injection book out today, let's see what those codes mean.
172: Lack of O2 Switches, indicates lean.
326: EGR sensor circuit voltage lower than expected
327: EGR circuit below minimum voltage
634: Manual Lever Position sensor voltage out of self-test range
The only thing I see in common there are voltage issues (save for the O2 sensor, which could be giving you that reading because of the EGR fault). I'd take a close look at the wiring harnesses that the EGR and transmission wiring take off from, and see if there's something burned through or broken.
awesome... the codes seemed to start sometime after I got the transmission rebuilt, so I will check the harnesses next.
On my bird, I do the thing with the number 15 fuse to reset the computer. Is there a similar procedure on the older systems?
5oh Transformer
i like how its acronym should be tccoa but its not, cause we're better. ha lol jk
