I just got a used Noszle kit from my friend that had it on his 4.6 2V mustang. I am installing it on my 1995 Lincoln Mark VIII. So far I have the nitrous line run into the interior, and I removed the schrader valve from the fuel rail and ran my fuel line to the kit before the regulator. All I have left to do is run my wires, and plug the fuel injectors into the NOSzle injectors. I have to come up with a way to bolt the fuel rail to the motor properly also.
I will take pictures next weekend when i get back home, and will let you guys know how it goes. So far it looks like it should work on the 4v no problem.
I have always liked the NOSzle kits, but they were just too pricey and out of my price range!
Make sure you check the flow through each nozzle. Those passages are small and they could get clogged easily. Not so bad if the nitrous side gets clogged, but if you lose the fuel side…. it would be bad…
Definitely post some photos. :thumbsup:
