Ok, so the car has began running somewhat rough, like it isn't getting enough juice, at idle with either the heater or ac on. It only happens when its stopped, either in gear or out. It idles, drops down to around 200 rpm, the volt guage dips, and then it idles back to normal, guage goes back to normal...
It does this in a cycle, no matter what the setting of the heater/ac is.
I just replaced the battery and alternator last winter. I also replaced the plugs and plug wires last winter also.
Any ideas of what could be going on??
It only started doing this after I seafoamed the engine and cleaned the maf. As I said before, the car runs fine, just not at idle with air or heater on.
Any suggestions on things to check out?
ok, that would make sense, Ill check it out, thanks guys
