Did a complete front suspension about 3k miles ago.
Went to fill the washer fluid and I noticed the big center nut on the strut was about 1/2 way off and the washer was loose!!!!
If I remember right it was the only nut that I didn't blue locktight or use a new nylon nut on the whole car.
I just blue locktited the nut and tightened it with a wrench holding the top of the strut with a small wrench. Measured the distance from end of strut to nut and it was the same 1.5 or so inches on both sides.
Really made me nervous so I checked every single nut I replaced.
I did swap out the stut / spring assembly on my own....
Any ideas or hopefully it should be good now...
Thanks!
Fry Rice Specialist
if you put blue locktite now you'll be fine. mine is blue loctite and double nut.
Well it's supposed to be a locking nut, and you're supposed to use a new one that comes with the shock.
The new shocks do not come with nut, or at least the Motorcraft ones I bought a few years back didn't. I had the same issue with my car but it was not that the nut came loos but that the nut was not fully seated when the spring was installed.
-Miller
