ok, so I have a check engine light. I scanned it and its for a rear bank 2 oxygen sensor. I took a rag and held it in front of both tailpipes to see if it may be a bad cat causing the o2 sensor to misread. the passenger side tailpipe seemed to move the rag just a little less (a very small amount, I am not completely sure if I am even making it up) and there seems to be a misfire at idle on that side, which I noticed happening maybe three times as much as on the drivers side. if it was a bad cat, would it not move the rag at all, or would it be a hardly noticable difference to the drivers side?
thanks,
steve
thanks,
steve
