Just want to put these out for help to anyone,
OBD II Diagnostic Codes
P0700 Transmission Control System (MIL Request)
P0703 Brake Switch B Input Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor Circuit (PRNDL Input) *
P0707 Transmission Range Sensor Circuit Low Input *
P0708 Transmission Range Sensor Circuit High Input *
P0712 Transmission Fluid Temperature Sensor Circuit Low Input ^
P0713 Transmission Fluid Temperature Sensor Circuit High Input ^
P0715 Turbine Shaft Speed Sensor Circuit *
P0717 Turbine Shaft Speed Sensor Circuit No Signal
P0718 Turbine Shaft Speed Sensor Circuit Intermittent ^
P0720 Output Shaft Speed Sensor Circuit *
P0721 Output Shaft Speed Sensor Circuit Range/Performance ^
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0731 Gear 1 Incorrect Ratio ^
P0732 Gear 2 Incorrect Ratio ^
P0733 Gear 3 Incorrect Ratio ^
P0734 Gear 4 Incorrect Ratio ^
P0735 Gear 5 Incorrect Ratio ^
P0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off ^
P0743 Torque Converter Clutch Solenoid Circuit Electrical *
P0745 Pressure Control Solenoid A *
P0746 Pressure Control Solenoid A Performance or Stuck Off *
P0750 Shift Solenoid A *
P0751 Shift Solenoid A Performance or Stuck Off *
P0755 Shift Solenoid B *
P0756 Shift Solenoid B Performance or Stuck Off *
P0760 Shift Solenoid C *
P0761 Shift Solenoid C Performance or Stuck Off *
P0765 Shift Solenoid D *
P0766 Shift Solenoid D Performance or Stuck Off *
P0770 Shift Solenoid E *
P0771 Shift Solenoid E Performance or Stuck Off *
P0775 Pressure Control Solenoid B *
P0779 Pressure Control Solenoid B Intermittent
P0781 1-2 Shift ^
P0782 2-3 Shift ^
P0783 3-4 Shift ^
P0791 Intermediate Shaft Speed Sensor Circuit
P0794 Intermediate Shaft Speed Sensor Circuit Intermittent ^
P0795 Pressure Control Solenoid C *
P0796 Pressure Control Solenoid C Performance or Stuck Off *
P0797 Pressure Control Solenoid C Stuck On *
P0799 Pressure Control Solenoid C Intermittent
P0812 Reverse Input Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0818 Driveline Disconnect Switch Input Circuit
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P1000 OBD Systems Readiness Test Not Complete
P1001 KOER Not Able to Complete, KOER Aborted
P1100 Mass Air Flow Sensor Circuit Intermittent
P1101 Mass Air Flow Sensor Out Of Self Test Range
P1109 Intake Air Temperature B Circuit Intermittent
P1112 Intake Air Temperature Circuit Intermittent
P1114 Intake Air Temperature B Circuit Low Input (Super/Turbo Charged engines) *
P1115 Intake Air Temperature B Circuit High Input (Super/Turbo Charged engines) *
P1116 Engine Coolant Temperature Sensor Out Of Self Test Range
P1117 Engine Coolant Temperature Sensor Circuit Intermittent
P1120 Throttle Position Sensor A Out Of Range Low (Ratch too low) *
P1121 Throttle Position Sensor A Inconsistent With Mass Air Flow Sensor *
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1124 Throttle Position Sensor A Out Of Self Test Range
P1125 Throttle Position Sensor A Intermittent
P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tested
P1128 Upstream HO2S Sensors Swapped
P1129 Downstream HO2S Sensors Swapped
P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit *
P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean *
P1132 Lack Of HO2S11 Switches - Sensor Indicates Rich *
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC) [ *]
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC) [ *]
P1135 Pedal Position Sensor A Circuit Intermittent
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switches - Sensor Indicates Rich
P1150 Lack Of HO2S21 Switches - Fuel Trim At Limit *
P1151 Lack Of HO2S21 Switches - Sensor Indicates Lean *
P1152 Lack Of HO2S21 Switches - Sensor Indicates Rich *
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC) [ *]
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC) [ *]
P1155 Alternative Fuel Control Module Has Activated the MIL
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich
P1168 Fuel Rail Pressure Sensor In Range But Low
P1169 Fuel Rail Pressure Sensor In Range But High
P1180 Fuel Delivery System - Low
P1181 Fuel Delivery System - High
P1183 Engine Oil Temperature Sensor Circuit *
P1184 Engine Oil Temperature Sensor Out Of Self Test Range *
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1220 Series Throttle Control System
P1221 Traction Control System [ ] [ ] [ ]
P1222 Pedal Position Sensor B Circuit Low Input
P1222 Traction Control Output Circuit [ ]
P1223 Pedal Position Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1227 Wastegate Failed Closed (Over pressure) *
P1228 Wastegate Failed Open (Under pressure) *
P1229 Charge Air Cooler Pump Driver *
P1230 Fuel Pump Low Speed Malfunction (VLCM)
P1231 Fuel Pump Secondary Circuit Low, High Speed (VLCM)
P1232 Fuel Pump Speed Primary Circuit (Two speed fuel pump)
P1233 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module) *
P1234 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module)
P1235 Fuel Pump Control out Of Range (Fuel Pump Driver Module/VLCM) *
P1236 Fuel Pump Control Out Of Range (Fuel Pump Driver Module)
P1237 Fuel Pump Secondary Circuit (Fuel Pump Driver Module) *
P1238 Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
P1239 Speed Fuel Pump Positive Feed
P1243 Second Fuel Pump Fault or Ground Fault *
P1244 Alternator Load High Input
P1245 Alternator Load Low Input
P1246 Alternator Load Input
P1260 Theft Detected, Vehicle Immobilized
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1285 Cylinder Head Overtemperature Condition
P1286 Fuel Pulsewidth In Range But Lower Than Expected
P1287 Fuel Pulsewidth In Range But Higher Than Expected
P1288 Cylinder Head Temperature Sensor Out Of Self Test Range
P1289 Cylinder Head Temperature Sensor Circuit High Input
P1290 Cylinder Head Temperature Sensor Circuit Low Input
P1299 Cylinder Head Overtemperature Protection Active *
P1309 Misfire Monitor AICE Chip Fault, Misfire Monitor Disabled *
P1310 Ionization Misfire Detection Module Fault *
P1311 Ionization Misfire Detection Module Communication Fault *
P1340 Camshaft Position Sensor B Circuit *
P1351 Ignition Diagnostic Monitor Input Circuit *
P1352 Ignition Coil A Primary Circuit *
P1353 Ignition Coil B Primary Circuit *
P1354 Ignition Coil C Primary Circuit *
P1355 Ignition Coil D Primary Circuit *
P1356 Ignition Diagnostic Monitor Indicates Engine Not Turning *
P1357 Ignition Diagnostic Monitor Pulsewidth Not Defined *
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range (no CPU OK)
P1359 Spark Output Circuit *
P1360 Ignition Coil A Secondary Circuit [ ]
P1361 Ignition Coil B Secondary Circuit [ ]
P1362 Ignition Coil C Secondary Circuit [ ]
P1363 Ignition Coil D Secondary Circuit [ ]
P1364 Ignition Coil Primary Circuit *
P1365 Ignition Coil Secondary Circuit [ ]
P1366 Ignition Spare [ ]
P1367 Ignition Spare [ ]
P1368 Ignition Spare [ ]
P1369 Engine Temperature Light Circuit
P1380 Camshaft Position Actuator Circuit (Bank 1) *
P1381 Camshaft Position Timing Over Advanced (Bank 1) *
P1383 Camshaft Position Timing Over Retarded (Bank 1) *
P1385 Camshaft Position Actuator Circuit (Bank 2) *
P1386 Camshaft Position Timing Over Advanced (Bank 2) *
P1388 Camshaft Position Timing Over Retarded (Bank 2) *
P1390 Octane Adjust Service Pin In Use/Circuit Open
P0781 1-2 Shift ^
P0782 2-3 Shift ^
P0783 3-4 Shift ^
