Pin 16 (yellow wire) on the OBD II under dash connector is supposed to be “Hot At All Times”, I assume +12 volts. I am unable to read any voltage at all at the pin or use a basic hand held code scanner, as they are not self powered.
Can someone tell me what voltage pin 16 should read, and is there maybe a fuse I could check. The car is working fine but sooner or later I may have to scan for codes and I don't want any last minute surprises.
Thank you
Do you get voltage on both sides of the fuse? There is a hole that allows you to test the voltage without removing it, just put the negative side to ground and test each side. I don't remember now which side is hot and which one is fused, but battery voltage should be on either side, 12.8-whatever your battery is putting out.
Yes, I am getting 12 volts on both sides of the fuse. The manual does not indicate any inline fuse on this wire so it may be broken or disconnected.
Thank you.
Up Date
Obviously I am not guaranteeing this, but I tapped into the code reader side of the 16 pin connector with a 9 volt battery. Pins 4 and 5 are ground and connected to each other (not sure why) and pin 16 is +12 volts. Both plugged in or not, the reader has a bright display and behaves just as the manual predicts. I am talking about a Harbor Freight CEN-TECH CAN OBD II, which is apparently the same as a Geniscan GS300.
