Hello, bump for a good project thread source.
Where is the Thunderbird 4.6 engine harness connector on OBDII models? If they are at the back, for a 302 car I'd use the Explorer engine harness. The engine harness includes a connector to the trans harness, and the Explorer version fits perfectly of course. If the main connector is located at the back on both, use the proper engine bay harness for the car, and make any wiring changes at the engine connector.
Also note that for an Explorer PCM there are three choices. 1999+ has the new returnless fuel system, so match that to your car(fuel rail and injectors too). 1998 had the first PATS system, so if you don't plan to reprogram the PCM(Excal flasher), get a 96/97 computer so you don't have the PATS module to deal with.
I'm planning to rewire my 91 LSC this Spring. It's going to take more work, since my old EECIV engine bay harness is vastly different than any OBDII wiring. I also will have to convert my TEVES ABS system, and move or convert my air suspension. I see a 99 Mustang engine bay harness and ABS module being my starting point.
I'll also pull my dash(cracked and I have another), to modify the dash harness with several new things. I have spare Explorer wiring from my old 99 Explorer rebuild. I'm hoping I can swap the steering column to use the high end clock spring, to add the steering wheel and radio controls. Maybe I can also add the GEM module from an Explorer, which has cruise control and electrical relays, monitoring etc. Lots to think about, we'll see how it goes. Regards,
