I have a wires coming out of the bottom of the shifter handle that go to very small thin female connectors...not a plastic plug. I assume they are the od switch wires. Where do they connect??
I cannot seem to find open connectors.
There should be a black female plug under the cigarette lighter area about 1cm square. If all you have are the copper terminals it would seem they were forcibly removed from the plug.
Found it...just like you said. tHANKS!
